Hello, does anyone understand why this happens?
It’s a 2d case and i set a wind vector in the (-)y direction with a magnitude of 5. It seems like the flow spreads from a point.
I upload the GH file in case it’s needed.
Plan.gh (62.2 KB)
Plan.gh (62.2 KB)
@albesaca,
From the image screenshot, you provided prob’s (mesh) points to _analysisResult
values or as vectors
input. And it’s not CFD result.
Use Butterfly_Load Probes Value
component to load from solution and connect the outputs to relevant input for visualizing results.
My bad, i thought to have followed properly the example file but in the end it appears i wrong the final part.
Thanks for the help
