Adaptive Comfort Calculator - Target temperature
I would like to know what the “target temperature” field refers to in the Ladybug Adaptive Comfort Calculator component. Is it the line lying at the center of the comfort region? And how is it calculated? Any references is much appreciated.
Thanks!
Hi Ipek,
Yes. It is the line at the center of the comfort polygon. This temperature is famously known as Neutrality Temperature (Tn). You will find several resources for the same. This is one such reference. Where Neutrality temperature is defined as Tn = 17.7 + 0.31 * Tav. Where Tav is the mean temperature of the month.
-Devang
2 posts were split to a new topic: Why do I get this error: Expected float or DataCollection?
Hi Ladybug team
I have a question about LB Adaptive Comfort
. How can I get “Upper Temperature Bound” and “lowerTemperatureBound” in the new version ?? I used to calculate them in the legacy version.
Yes this upper and lower temperature bound was very useful in the old ladybug, i hope it can make it’s way into the new one again.
