Butterfly Beta Release for Grasshopper and Dynamo
We are very excited to finally release the Butterfly plugin for both grasshopper and dynamo on this lovely first day of Spring! After several rounds of development, testing, and modification, Butterfly has finally metamorphosed to have all known major bugs fixed and is ready to be used by a larger number of people in our community.
Butterfly is powered by OpenFOAM, which is a validated and open-source engine for Computational Fluid Dynamics (CFD). Primarily, Butterfly assists with exporting geometry and other input parameters from the CAD + scripting interface to the OpenFOAM engine. The Grasshopper plugin supports live results visualization that updates as the CFD simulation iterates. The Dynamo plugin supports results visualization once the analysis is over or paused.
For installation instructions and guidance on getting started, check out the Butterfly wiki page. There, you can find step-by-step installation directions and tutorial videos. There also 3 YouTube playlists for getting you started with installing OpenFOAM for Windows and using Butterfly for Grasshopper and Butterfly for Dynamo.
Similar to other ladybug tools, Butterfly uses an external validated engine (in this case, OpenFOAM) and you need to install it first to get the insect up-and-running. However, unlike Radiance and EnergyPlus, OpenFOAM doesn’t have a native installation for Windows and it requires Linux to run. Accordingly, the current version of “OpenFOAM for Windows” uses a technology called docker to run a Linux virtual machine on your system, inside which OpenFOAM operates. While this sounds complicated, the good news is that all of this setup has been packaged into the installer for “OpenFOAM for Windows.” So running this installer with all its defaults should give you everything you need.
The bad news is that the installation can fail if you don’t check your Windows system properly beforehand or don’t follow every step carefully afterwards. You will also need to run Rhino, Revit, and OpenFOAM as an administrator to ensure Butterfly works properly (by right-clicking each launcher for the program and selecting “Run As Administrator"). This said, if you follow the steps carefully, you should have no issues with the installation. You can find some of the issues that people faced during the alpha testing and the solutions to them here.
Butterfly is the first plugin that is fully developed based on the structure that I discussed before which consists of a core library and [+] libraries for specific software (in this case Grasshopper and Dynamo). We hope this structure to extend ladybug tools to more platforms by re-using the current code. We will provide a better documentation with more details on this matter in the near future but for now you can use the API for butterfly, butterfly_grasshopper and butterfly_dynamo for customizing or extending the current development.
Finally, having access to a powerful CFD engine from inside parametric/generative modeling environments is a great power and as Spider-Man or Uncle Ben once said:
“with great power comes great responsibility!”
We believe in learning by doing and we don’t expect you to be a CFD expert to get started with butterfly however we expect you to educate yourself along the way. If you have never used OpenFOAM before here is a great presentation to get started. We also highly recommend checking out the official OpenFOAM User Guide that goes through most of its functionality. Finally, we have also collected a number of other learning resources on this page that can be a good starting point.
We understand that you will have questions about the plugins which you can post to this forum or Dynamo discussion forum however CFD related issues and questions should be posted to CFD Online.
I like to thank everyone who have helped us with the development and testing during the last year or so, and special thank to Theodore who single-handedly educated me through the process of migrating to OpenFOAM and developing butterfly. Butterfly wasn’t possible without Theodore!
As always let us know about your comments and suggestions.
Happy flying the butterfly! Happy Spring!
Awesome. Nice work. Looking forward to trying it out !!!
Fantastic! Thank you, guys!
Looking amazing guys!! Congratulations on release!!!
Great Work Mostapha , looking forward to give it a try
What an amazing achievement! Congratulations!
So great!! I’m not sure if i’m responsable enough … :slight_smile:
Thanks a lot for the new insect.
Amazing!! Can’t wait to try it out
Keep up the good work!
Great as always! Many congratulations Mostapha, Theodore and other developers.
Congrats Mostapha and team!!
Hi Mostapha,
Great news on Spring Equinox 2017;)!
Many thanks. Love your works and Happy Spring.
Kind regards,
Extremely exciting! Congratulations!
I’m sure it enables a variety of new research directions
I’m a bit puzzled as to why this would even be called a Windows “release”. It runs only in a VM and can’t be used by non-administrator users? I hope you realize many people in large organizations do not use their computers with Administrator accounts?
I have discussed this in the video. Not much that we can do about this at this point. See here: https://github.com/ladybug-tools/butterfly/issues/142
Thanks for everything! I was just worrying about no software available inside GH and BANG! I found butterfly. Thanks again for these powerful tools!
Hi Mostapha,
I used butterfly for a 100m tower simulation, however it is really slow to run the whole process. So is there any way to light the process?
Hi Lei,
It depends on the number of mesh cells. You can use parallel run to make the process faster, or you can use a 2d study if that fits the purpose. Please open a new discussion for questions like this.
I Mostapha, thanks for your tools. I install Meshtoolkit but I meet anyway the E error, “E is not a butterfly geometry”…some advices?
It could depend to Dynamo version, I’m using this one:, thank you very much!!
