Decomposing a custom construction
Hello friends
Is there a away to decompose a custom construction (to see the overall values, i.e., U-Value)? By this I mean the newly construction not the EP individual materials (layers).
I have attached .gh of a similar case of mine.
Thanks
Hardi
Custom Construction.gh (473.1 KB)
@HardiBarznji,
Please use Honeybee_Decompose EP Construction. That should solve your problem.
Yes devang, I simply forgot to use it on the panel itself, instead I used on the EP construction component!
Thank you
