does anyone knows why Dragonfly doesn’t complete the installation in a proper way? I simply run the .gh from the sampleFiles folder downloaded from GitHub.
It gives this error:
Solution exception:Could not add reference to assembly DynamoCore
Honeybee, Matlab compiler 9.0 and UWGv4.1 are installed properly.
You are looking in the wrong folder on the github. The platform-agnostic version of the Dragonfly core is not finished yet. You want to just install the userobjects from here and then you will be all set:
