Dear All,
Is it possible to manipulate zone volume (or height) in idf file using a honeybee component?
Thanks
There is no easy way! You can write the idf file. Load the file and edit Zone string and save the file back. Definitely not an ideal workflow.
Update: I added a new component that allows you to overwrite the volume.
Awesome! Zone multipliers were the last critical thing on the list for people wanting to build large full-building models. Thanks for implementing this @mostapha !
Just noticed the update. Great job. Thank you Mostapha
