I appreciate greatly your support.
I will try first to narrow down the stations I will need the most and leave the others out.
I will let you know!
Best regards,
Federico
Best regards,
Federico
Hi @Federico587, I checked the file for Yuzawa today and the error was because there were several extra , at the end of each line. I added an extra check to handle cases like this:
I cannot recreate this error. Can you update your installation and use the latest version from GitHub and test the files again. It might be fixed after the recent modification that @devang has made to sunpath.
Hi @mostapha,
thanks very much for having a look at this.
How should I do this? You mean install the last version of HB and LB legacy? Or use the update components on GH canvas?
Another thing: for what I can understand you solved the problem for ladybug (legacy). Do you think it can be done also for HB legacy and HB[+]?
I am gonna check the files as soon as I can and I will get back at you.
Best regards,
Federico
Hi @Federico587, The fixes are all for Ladybug[+] and Honeybee[+]. Ladybug legacy doesnât have a WEA component. By updating the plugins I meant updating Honeybee[+] plugins which can be done manually or by using this component.
Iâm wrapping up a new installation package for the [+] plugins. If you can wait until the end of the week then you can download the new version which has multiple bug fixes and improvements.
i seem to have a similar issue with this component but not sure it comes from the same reasons.
I tried both with an epw. file on my computer and from url directly
i got this error message : â1. Solution exception:from_epw_file() takes exactly 2 arguments (3 given)â
Any idea about it ?
Related to my HB[+] version maybe ?
Itâs OK finally, my version of the component wasnât the last updated one available
