Hi!
I am running a parametric analysis of a simple shoe box.
For each simulation I get 0,5 Gb of result data.
Is there a way I can still save data for each iteration but consume less space?
For example use the same sky and not save it?
Bests,
Federico
Hi @Federico587,
Sharing the sky files is possible but needs a lot of development on your side. An easier approach is to delete temp
folders which includes the rgb files. You can also delete the result/matrix
folder if you’re happy with the final results. It includes the daylight coefficient matrices.
