After the release of the HB[+] i started to do the obvious thing: compare the legacy results with the [+].
I’m testing the 00_point_in_time_gridbased.gh example and i’m having trouble with the climatebased sky component.
For ALL weather files in my country i get 0 values. See below image:
While the legacy produces the following:
I suspect the issue can be with the WEA creator ([+] uses wea while Legacy uses epw).
Visualizing the created sky i see it is completely black and seeing the globalHorIrradiance output of the watchTheSky it gives 0[+] and 995 [legacy].
Any ideas?
climatebased_vis_31.25_34.8_6_21_at_12_773_253.sky (277 Bytes)
