Honeybee+ Radiance parameters for Image Based Analysis
I am not able to adjust radiance parameters for HB+ image based analysis. I am only able to run images with default parameters.
If I use legacy HB parameter component the recipe component complains “1. Solution exception:<type ‘instance’> is not a radiance parameters.”
If I use HB+ grid based parameter component (the image based parameter component only seems to produce parameters for 3-phase analysis) everything seems to be fine with the recipe component but then Run Radiance Analysis says “1. Solution exception:input rcontribParamters is not a valid parameters type.”
Thoughts?
Are you looking to the right output? Based on the type of the analysis the parameters will be generated for different matrix calculations.
