Honeybee Results Validation
Dear @chris & @mostapha
I hope this message finds you both great
Do you have any suggestion what is the best way to validate honeybee results?
I know about the available processes like comparing with an experimented case or compare with a published simulated papers, but mostly there are not enough modelling information.
Although I am trying to compare the results based on the cases that are done in EnergyPlus and compared with other software as I attached here, but even in this file there are some unknown parameters that I can not find them in Honeybee for modelling, especilly the mechanical system type .
Thanks
epl_bestest_ash.pdf (502.9 KB)
Hi @AMIRTABADKANI, Have you seen this paper?
Thanks a lot @mostapha
This is exactly what I was looking for… Do you have any access to the written HB file on the paper ? It helps me a lot if I can see the file … Thanks again
I don’t. You should would contact the author of the paper directly.
