@Asisnath thanks for your help! The simulation is running and now I’m getting to grips with all the energy modelling. Looks like new versions are ok and running. The thing is to get up to date with new versions and in case clean the Windows registry, clean folders - if someone made an update.
Hi Mike,
I get the same warning message from the simulation:
Program Version, EnergyPlus, Version 9.2.0-921312fa1d, YMD = 2020.04.24 15:04,
** Warning ** Version: in IDF = “9.0.0” not the same as expected = “9.2”
** Warning ** Version: in IDF = “9.0.0” not the same as expected = “9.2”.
Open Studio 2.9.1 and Energy Plus V 9-2-0 are installed on my PC.
I tried to install Energy Plus V 9-0-1 (no Open Studio) to solve the problem but the simulation reports the same error.
How did you solve the problem?
Thanks for your help
Hi @Pol_IT,
first of all I have updated to Rhino 6. Try uninstalling EnergyPlus and OpenStudio. Then clean up you registry with some freeware software.
After I’ve installed just OpenStudio (no Energy Plus). And it should work.
Thanks @Mike_Rogozinski , I have followed your advice and now the warning no longer appears. Despite this, I still get several warnings.
Could they be due to the model or is it still a problem of incompatibility between software?
I attach the report
Program Version,EnergyPlus, Version 8.9.0-eba93e8e1b, YMD=2020.04.26 13:43,
************* Beginning Zone Sizing Calculations
** Warning ** ZoneHVAC:IdealLoadsAirSystem “ZONASUD_P1 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 3.58326E-002 [m3/s] exceeds limit.
** ~~~ ** Will be reduced to the Maximum Cooling Air Flow Rate = -99999.00000 [m3/s]
** ~~~ ** During Sizing, Environment=BRESCIA-GHEDI ANN CLG .4% CONDNS ENTH=>MDB, at Simulation time=07/21 24:00 - 24:10
** Warning ** ZoneHVAC:IdealLoadsAirSystem “ZONASUDOVEST_P1 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 2.25825E-002 [m3/s] exceeds limit.
** Warning ** ZoneHVAC:IdealLoadsAirSystem “ZONASUDEST_P1 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 2.25825E-002 [m3/s] exceeds limit.
** Warning ** ZoneHVAC:IdealLoadsAirSystem “ZONAINTSUD_P1 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 4.47501E-002 [m3/s] exceeds limit.
** Warning ** ZoneHVAC:IdealLoadsAirSystem “ZONANORD_P1 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 3.58326E-002 [m3/s] exceeds limit.
** Warning ** ZoneHVAC:IdealLoadsAirSystem “ZONANORDOVEST_P1 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 2.25825E-002 [m3/s] exceeds limit.
** Warning ** ZoneHVAC:IdealLoadsAirSystem “ZONANORDEST_P1 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 2.25825E-002 [m3/s] exceeds limit.
** Warning ** ZoneHVAC:IdealLoadsAirSystem “ZONAINTNORD_P1 IDEAL LOADS AIR SYSTEM” Requested outdoor air flow rate = 4.47501E-002 [m3/s] exceeds limit.
** Warning ** ManageSizing: For a plant sizing run, there must be at least 1 Sizing:Plant object input. SimulationControl Plant Sizing option ignored.
************* Testing Individual Branch Integrity
************* All Branches passed integrity testing
************* Testing Individual Supply Air Path Integrity
************* All Supply Air Paths passed integrity testing
************* Testing Individual Return Air Path Integrity
************* All Return Air Paths passed integrity testing
************* No node connection errors were found.
************* Beginning Simulation
************* Simulation Error Summary *************
** Warning ** The following Report Variables were requested but not generated – check.rdd file
** ~~~ ** Either the IDF did not contain these elements, the variable name is misspelled,
** ~~~ ** or the requested variable is an advanced output which requires Output : Diagnostics, DisplayAdvancedReportVariables;
************* Key=, VarName=COOLING COIL ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=CHILLER ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=BOILER GAS ENERGY, Frequency=Hourly
************* Key=, VarName=HEATING COIL TOTAL HEATING ENERGY, Frequency=Hourly
************* Key=, VarName=HEATING COIL GAS ENERGY, Frequency=Hourly
************* Key=, VarName=HEATING COIL ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=HUMIDIFIER ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=FAN ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=ZONE VENTILATION FAN ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=EARTH TUBE FAN ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=PUMP ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=ZONE VRF AIR TERMINAL COOLING ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=ZONE VRF AIR TERMINAL HEATING ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=VRF HEAT PUMP COOLING ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=VRF HEAT PUMP HEATING ELECTRIC ENERGY, Frequency=Hourly
************* Key=, VarName=CHILLER HEATER SYSTEM COOLING ELECTRIC ENERGY, Frequency=Hourly
************* Key=*, VarName=CHILLER HEATER SYSTEM HEATING ELECTRIC ENERGY, Frequency=Hourly
************* There are 1 unused schedules in input.
************* There are 1 unused week schedules in input.
************* There are 3 unused day schedules in input.
************* Use Output:Diagnostics,DisplayUnusedSchedules; to see them.
************* EnergyPlus Sizing Error Summary. During Sizing: 9 Warning; 0 Severe Errors.
************* EnergyPlus Completed Successfully-- 10 Warning; 0 Severe Errors; Elapsed Time=00hr 03min 57.58sec
