Ladybug_Bioclimatic Chart -runtime error
The error in runtime, type error exception:
“float” object is not iterable;
trace back: line 1336, in main, ""
line 1717, in script.
I need help. Thanks.
HI @TianYixin, Could you please attach a minimal version of your GH file? It’s really hard to judge the problem with this minimum description.
ladybug-xian-beidongcelve.3dmbak (38.3 KB)
A grasshopper file please?
I have solve this problem when I use rhino5. thanks
@TianYixin,
Can you send the file so we can see where is this happening and solve the issue for Rhino6?
@AbrahamYezioro,
It works for me. In Rhino 6.3 beta and 6.2 Ladybug_Bioclimatic Chart works fine.
@TianYixin, I just updated Abraham’s example you can find here.
BioclimaticChart_March.2018.gh (463.6 KB)
best.
Thanks @OmidmRashidi!!
Just curious now what make @TianYixin’s file to fail. Maybe there is something to fix anyway.
@AbrahamYezioro
My comuputer has rhino 5 and rhino 6 at the same time.
This software is great, I love it , although I have encountered a lot of difficulties.
support you. I hope it is becoming more and more friedly.
ladybug-bioclimatic error.gh (366.0 KB)
@TianYixin, Your components’ version is too old. you need too update your LB and also HB or it is better to download and re-install LB, HB again from Food4rhino.
BioclimaticChart to update-omr.gh (845.4 KB)
Omid.
Thanks again @OmidmRashidi.
Just to be on the safe side, @TianYixin, which weather file are you trying to use?
I have re-install LB+HB. The error has been solved. Thank you.
I use the China epw. weather which is download from energyplus.
https://energyplus.net/weather
Any problems?
Any specific location?
Hard to get info from you … :slight_smile:
