I am currently trying to use Gismo and Ladybug to generate terrain, and import the geometry into Envi-met for further simulation. However, when I connect terrain generated from Gismo to Ladybug_Envi-Met Building Terrain, warning will occur showing ‘’ Please move terrain’’. I tried to build terrain in a number of different ways, but couldn’t work it out. Does anyone know how to solve this issue?
Hi @chfyhpyyy129,
Hard to say without looking at how your buildings sit on the terrain. Why don’t you try to move the terrain in the +z direction as the component warning says? Looks like the buildings and the terrain are not being intersected.
the component which you use does not exist anymore, I have written several new components for ENVI_MET You can find the latest version of them on Github: lb_envimet
Here is a small workflow let you add a terrain in ENVI_MET.
