Hi @devang,
This is what is happening.
I tried with EPWs from Meteonorm and NREL.
Both give the same issue.
Any insight would be very helpful!
Hi @devang,
@Federico587 To add to Devang’s reply, you are are actually linking an EPW file to an input that requires a Radiance sky file. Hence, the component is crashing.
@devang, I am laughing so much for my ingenuity!
Thanks for the tip.
I used the Climate Based sky for a precise hour, as you showed, and also I try the entire year with gencomulative sky (you can see the pictures)
@sarith, the renderings you posted here in this tread are from native radiance or you used honeybee?, because for what I can tell you used gendaymtx maybe?
Hi @Federico587, I used Radiance to generate those images…something like gendaylit … rpict … falsecolor
