Optimisation with Honeybee + ASE and sDA not avaible anymore
#1
I have previously managed to use the outputs from sDA from Honeybee as an optimisation value, however with the new ASE and sDA in Honeybee +, even though the sliders are moving and changing the geometry, the results stays the same. Has anyone else had this issue?
Thanks
Taylor
#4
Hi @taylor_zhou, Did you set reuseDMtx on the recipe to False? By default it is set to True which means it loads the results of the previous study if available.
#5
Thanks @mostapha, that solved the issue. It is because in the previous Honeybee there used to be Overwrite files boolean, so i was not expecting it to be on the recipe.
#6
Great! Also be aware of the bug in honeybee[+] for calculating sDA which will be fixed in the upcoming release. You can still use Grasshopper to calculate it from DA values.
#7
@mostapha I don’t think i am aware of the bug you are speaking of, under what situation does the bug occur?
T
#8
See this: sDA calculation
#9
Thanks again, I just did some calc comparison just before I saw your reply.
T
