I was trying to run a gridbased daylighting simulation. but for some reason that oconv.exe always crashes.
The geometry is just a box model, and basic materials.
couldn’t figure out what happened to the oconv.exe.
I attached the study folder and a screenshot of this error.
Can anyone help me double check with it? @MingboPeng
Radiance version? Check it inside Honeybee?
It is working on my two computers, and even my working pc. I am thinking if he has a Chinese computer account.
Which version of windows is he using and can you translate what the error says? I am also wondering if oconv starts at all. You can try something like this to check if it is working.
I had solved the problem。 Thank you sincerely. In fact, some DirectX files have been lost. We can download a DirectX Repair to solve the problem. If you have this problem, you can try this plug-in.
This problem might happen to some other Chinese users, as they often to use some computer cleaner tools, which would disable some functions that most of user don’t need.
