Hello everyone.
I am dealing with a radiation analysis for a simple surface with a shading device.
I have the intention to perform 100 000 simulations including different shading geometries.
Thanks to anemone, I create a program which is able the scroll through all possibilities and for each one , performs a radiation analysis simulation. Each simulation lasts 1 second.
The problem is that as far as the iteration index is getting higher ,the simulation time consumption is getting greater ( from 1 second to 2 seconds).Also the rhino memory allowance, as well as analyse time consumption, is getting larger. Moreover, I find out that Lady bug radiation analysis component contributes mainly in this memory issue.
I have tried to clear and recompute solution, but unfortunately rhino allowance memory stays as higher as before.
I looked at Radiation analysis code, and it appears that no dispose() or garbage commands are applied.
Has anyone ever been in such a situation before?
I have no clue how to deal with this issue. I will be very pleased with your contribution.
Thank you in advance.
