I am trying to use SolarFan_alt Component but when I input a number to _height input I get an error : "1. Solution exception:unsupported operand type(s) for //: ‘str’ and ‘float’ ". I use the latest github component. Any ideas?
Saeran, My guess is that Tatos is using a panel to input the number and since you haven’t clarified the input type explicitly GHPython component considers it as a string and that’s why the issue happens. If you change it to float that should avoid this issue.
Hey Mosstapha, I think you’re right, thanks for pointing it out. I thought I had all the input types set, but looks like I missed this one. I’ll block some time out in order to update this.
Hello, sorry I missed your request. It looks like the site’s up again so I hope you had a chance to read it.
For anyone else, if the site goes down again these are the details:
Solar Availability in Cities ISSN: 1833-7570, Issue No. 006, May 15, 2012 Solar Availability in Cities: A Design Approach By: Spyros Stravoravdis and Andrew Marsh.
I’m late to the discussion, but I wanted to add some points regarding your central questions.
First, the SolarEnvelope guarantees solar exposure for a specified amount of time, at the plane at which it is defined, not just the ground plane. So technically you can apply it at a higher level to guarantee solar exposure for the facades of surrounding buildings (for passive solar gain) although this obstructs solar access at ground level.
You’re right that by limiting the south side, you’re limiting the passive solar energy potential for the building mass within the SolarEnvelope. But I think this gets at a broader point about the use of this tool in the context of building energy performance: it’s only one strategy amongst many, and many of these strategies will contradict each other.
Here are a couple examples of relevant conflicts, off the top of my head, to your problem: (1) in order to maximise passive solar gain, it would be ideal to concentrate built massing on the north side side of the lot (increasing solar exposure on the south face) - as you suggest - but that would then obstruct solar exposure to the south face of the building immediately north of your site. (2) Increasing the surface area to passive solar gain and daylighting could reduce building energy, but it can also increase building energy due to surface heat loss, or increased air conditioning loads. If air conditioning loads are high, it would be better to do the opposite of the solar envelope, use the neighbouring massing to obstruct heat gain.
So the interaction between overshadowing, passive or active energy gain, built massing, glazing ratios and building energy is complicated. A couple of things you need to address: what is the dominant load in your buildings - is it heating (like residential) or lighting (like office)? You may require different energy strategies for each. If the building is multi-use, you have an opportunity to combine different strategies. I believe commercial ground programs for example usually don’t require daylighting or passive solar gain, as their primary energy load is air conditioning. As I mentioned above, you can therefore raise the SolarEnvelope, ignoring the ground plane, and instead focusing solar exposure to neighbouring facades.
Keep in mind that at a certain point (as I believe the paper Chris linked mentions) SolarEnvelopes constrain density to a point where it can be detrimental to broader urban goals. So if you want higher densities I wouldn’t use the SolarEnvelope so ‘strictly’.
Off the top of my head, the workflow I would suggest is modelling a series of planar surfaces, and then applying, one by one, the radiation analysis on them.
I don’t think a 3d grid would work, for the same reason you’d have to run the radiation analyses separately: you’re going to want to avoid self-shading geometries. This is only a pain if you want a denser 3D grid, in which case you might want to look into creating a GH or Python script script to automate the isolation and application of your radiation analysis.
Thanks for your reply. I was also thinking that a dense grid would take immense calculation times.
I’m also leaning towards the planar surfaces idea. I think drawings isolines of different illuminance values on each plane and then using GH native components to create 3d surfaces from these isolines could do the trick. It would be rough but ideally there could be some automation on increasing accuracy (i.e. number of planes). I wonder if the parametric definition by Mostapha can be adjusted for this.
Anyways, I’m not as versed in GH scripting but I’ll let everyone know if I had some success.
The sort answer is that you can use the solar fan for windows. See attached for an example file showing a solar fan around a window for a solar passive house that needs solar access when it is very cold:
What is the best way to get a solar fan for a specific analysis period for a min number of hours, for example 21 June 9am-3pm for 2hrs?
Solar fan basic allows required hours, but onlt a monthly range. Whereas solar fan I can specify the sun vectors (i.e. analysis period) but not the required hours.
Just on the top of my mind (haven’t tried it not currently on the pc), I guess you can specify an analysis period when you are generating the sun vectors for your study. Is that what you are looking for?
Analysis period will just give you a range, say from 9-3pm. If I use this the solar fan will ensure light is ALWAYS accessing the surface. However, I can accept a min of 2hrs and I can’t find a method to do this. Sunlight hour analysis can sort of do this but only in 2d, not 3d.
Sorry Paul, I don’t think I understand what you are asking for. Do you mean you want a way to specify a specific time and month range for solar fan/ envelope?
What is the best way to get a solar fan for a specific analysis period for a min number of hours, for example 21 June 9am-3pm where each part of the surface receives at least 2hrs?
The ‘Solar fan basic’ component allows required hours (2 hrs), but only a monthly range (so I can’t specify 21 June). Whereas, the ‘solar fan’ component I can specify the sun vectors for a specific analysis period (21 June) but not the min required hours.
Thanks that’s better. This can easily be resolved with the solar fan basic, I just need to modify it to take custom monthly ranges. I am at work now but I’ll get to this when I have some free time.
Update: I think the attached file should do want you want. I have the script there set to June 21.
For the record, you should be able to do this with the other solarfan/solarenvelope tool: you just have to set the time range around the location’s solar noon.
I threw this together quickly, so let me know if there’s any glitches I overlooked.
