I was going through the 3-phase example and was trying to understand the window group sequence used in the blindCombs input of the blind states component.
(-1,1,-1) = (side window, south window, skylight) = (closed, diffuse, closed).
is that right?
or does the window group get applied to the index value like this:
This one is correct. Each row is the combination of states for different window groups. It gives you a flexible solution to define dynamic blinds logic for each AnalysisGrid/Zone.
I’m working with 4 states for each windows groups. You write the blinds-state as following:
(0,0) = (generic window non blinds, window group with venetian blinds) = (clear, blind open).
(0,1) = (generic window non blinds, window group with venetian blinds) = (clear, blind closed 25° above orizzont).
(0,2) = (generic window non blinds, window group with venetian blinds) = (clear, blind closed 45°).
(0,3) = (generic window non blinds, window group with venetian blinds) = (clear, blind closed 60°).
