1. All of your HBSrfs must make a closed volume
HELLO GUYS,
I HAVE THIS SIMPLE PROBLEM THAT I CAN NOT RESOLVE, EVEN MY VOLUME (Z4) CLOSED, BUT HB HOW TO MAKE ME THIS ERROR:
“1. All of your HBSrfs must make a closed volume.”
Can you help me please?
TEST - V00.04 - 2017-09-28 - DB .3dm (132.3 KB)
THESIS - V00.04 - 2017-09-26 - DB.gh (951.2 KB)
ITA_Venice.161050_IWEC.epw (1.5 MB)
Hi Davide,
Zone Z4 is not closed. Please, check “PAVIMENTO_Z4” and “SOFFITTO_Z4”. Basically, you use the same surface for both.
If you connect the right surface the warning disapper.
Regards,
Antonello
Grazie mille @AntonelloDiNunzio,
era un errore banale ma purtroppo non riuscivo a trovarlo.
Grazie ancora.
Unfortunately after solving the geometric problem, has come out this problem that I can’t solve.
Sorry if I waste your time:
  1. The simulation has not run correctly because of this severe error:
    ** Severe ** ComputeIntSolarAbsorpFactors: Solar distribution model is set to place solar gains on the zone floor,
THESIS - V00.04 - 2017-09-26 - DB.gh (958.9 KB)
Thank you
Hi Davide,
it depends on Boundary Conditions of surfaces. I suggest you open a new discussion, because this is another kind of issue (other topic).
Regards,
Antonello
