hi there I installed hb and lb version legacy but im getting an error 1. Default file path can’t have white space. Please set the path to another folder.
Honeybee failed to fly! what can I do?
Hi @pooria
Energy plus does not except white spaces and other special characters. In the new lbt version the LBT team made a work around for this. In the Legacy version you will need to put your files in folders without white spaces.
hi sir thanks for your helping. what do you mean from folders without white spaces? may you show the picture im getting counfused.
