1. Solution exception:'Brep' object has no attribute 'geometry'
Hello all, i am just starting to teach myself honeybee using chris makey 2015 youtube series. i have come across this issue though : 1. Solution exception:‘Brep’ object has no attribute ‘geometry’. and cant find anything that i can understand to fix it. anyone know what the issue is? also is the chris mak series the best to follow for energy modelling? thanks in advance
You are mixing Legacy and LBT versions. They don’t work together.
