1. Solution exception:'Location' object has no attribute 'split'
what’s wrong?
@Aliarch
Hi @zahrashirzadnia,
You are mixing a Legacy component with a component from the new version. You should replace the sky component with the new version. Before you do that you should run LB Versioner to update the core libraries and components.
Alternatively if you actually intent to use LB-Legacy then you should replace the EPW component with its Legacy counterpart.
Hi Sir,
thanks a lot for your complete describing.
