A problem about run OpenFOAM as administrator
Hi guys! I tried to use the Butterfly, but it showed an error which is “Solution exception:In order to run OpenFOAM using butterfly you must use an admin account or run the program as administrator.” I’m sure that my account has the administrator authority and I run OpenFOAM as administrator. Anyone knows how to solve this problem? Any help will be appreciated.
You have to run Rhino as an administrator too, did you try that?
If this is not obvious to some users, opening Rhino as an administrator involves right clicking on the Rhino app icon, or shortcut, and selecting “run as administrator”.
Happy Butterflying.
