A problem of running several E+ simulations at a time?
I‘m trying to run a sensitivity analysis about energy consumption of building. And,I have a large number of simulations to run. So,I want to know is there a way to run files in parallel.
I have tried “re-run IDF”, but I don’t get any data. And I also can’t find the result file under the result address.
Many thanks!
Xiaoqian
Hi I dont know how to run sims at the same time, but I know you can use Colibri to set them up to run one after an other.
