A problem with Voronoi window
Hello Dears,
I have a problem while using the energy loads component. It works with the simple box, but when I try to add a Voronoi window gives me this error message “1. Solution exception: There must be at least 3 vertices for a Face3D boundary. Got 2”. I am waiting for your kind help.
Hi @randa_medhat86,
First, read this post for some of the best practices to get help on this forum: https://discourse.ladybug.tools/faq
To answer your question your form is generating some line-like geometries with 2 vertices which is invalid in an energy simulation. Try to find and remove them from your model before sending them to energy simulation.
Hi @mostapha
Thank you so much for your kind reply
I will try to do what you said
Thanks for the attached link
Best Regards
