Accessing Zone Information
Hi Ladan,
You can iterate through all the zones using native grasshopper list item component. With that you can definitely select the zone you want to assign properties to. I have attached an example.
-Devang
MultiZone.gh (499 KB)
They are showing as ClosedBrep because that is what they are in Grasshopper. To answer rest of your questions besides what Devang has already answered.
  1. To see the name and the program of the zone you can connect them to askMe component.
  2. You can access loads and schedules by using the components under tab 05.
access zone data.gh (486 KB)
Thank you very much! this was exactly what I was looking for. I appreciate that.
Ladan
