Hi everyone, I the geometry that I use is coming from IDF file. I want to add shading to all the windows but when I use EPWindowShade I have an error: 1. Solution exception:‘str’ object has no attribute ‘append’. Attached a Screenshot of my work.
Thanks !
Did you find any solution to this? I am facing the same issue
Hi vanageso, Yes the problem is solved. I rebuild my entier buliding and it works. I don’t know the difference between the two models but it works…
