Additional String for the Adaptive Comfort Map
Hey everyone!
I was wondering if it’s possible to input additional strings to the AdaptiveMap component, similarly to what is enabled by the ModelToOSM component, as I intend to input some custom ground temperatures.
Best regards,
Gustavo
It’s not currently supported but I’m planning to eventually support something like this by allowing you to plug OSM and IDF files directly into the thermal map components. The only thing that’s really needed for this is an input that allows you to specify “additional sensor grids” since the OSM and IDF formats don’t have a means to store the sensor grid information.
Once I we have this, you’ll be able to create whatever OSM or IDF you want with whatever measures or additional strings you like and evaluate the thermal comfort of it.
If all goes well, I should hopefully be able to add this before the next stable release.
