Adiabatic elements, Energy plus simulation
Hi everyone! I’m trying to do ad integrated daylight and energy simulation. I’ve got a simple room with floor, ceiling and 3 walls adiabatic. Only one isn’t adiabatic and it has 2 windows on it. To set the elements I used CreateHBsrfs and I added “Adiabatic” in the EPBC input. Since the EnergyPlus results weren’t what I expected, I checked the idf file and I discovered none of the element is adiabatic. Furthermore, the simulation doesn’t use the materials I set up for the not-adiabatic wall.
I even tryed with MakeAdiabatic, MakeAdiabaticbyname and MakeAdiabaticbytype.
With the first and second the problem is still the same.
With MakeAdiabaticbyType, if I change one wall type in the CreateHBsrfs, it still remains the same type in EnergyPlus, so it makes all the walls adiabatic.
Is there something I can do?
I attach the GH file
Thanks in advance
Lisa
IEA_18 07 2017_EPSimulation.gh (1.02 MB)
The open office program overrides boundary conditions assigned by you.
-Devang
IEA_18072017_EPSimulation.gh (1.02 MB)
Lisa,
To second Devang, there’s no need to use the “Masses2Zones” component in your file. You are already creating the zone with the “createHBZones” component and there’s no need to re-create it afterwards. Just plug your zoneProgram to the “createHBZones” component and things should work as you expect.
-Chris
HI! Thank you both for your replies! Sorry if I didn’t answer before but I didn’t see Devang’s reply.
It seems like it works now! thank you very much!
Lisa
