I’m posting this error/solution so others can find the cause in case they run into it. It’s pretty obscure.
When I change the fan placement from “Draw Through” to “Blow Through” within the AirDetail component while using HVAC systems 5 and 7 E+ fails and I get the following error:
- The simulation has not run correctly because of this severe error:
** Severe ** HVACControllers: Missing temperature setpoint for controller type=Controller:WaterCoil Name=“CONTROLLER WATER COIL 1”
All other HVAC systems types are fine. Should a warning message be displayed if the user inputs this setting combination?
