Analysis Period Error?
Inline image 1
Realized I posted this in the wrong place so I’m re-posting here. I get an error when using the analysis period in combination with the Sun Path. I didn’t notice it affecting any other component.
I understand the error in the code, I think, just no idea how to fix it myself.
Hey Brent,
I can’t see the image but I guess you get the error that LB_Preparation has no numOfDaysEachMonth method?
If that is the case then you have an older version of Ladybug flying in your Grasshopper. Make sure the version of Ladybug_Ladybug component matches the version of sunpath. Let the 'bug fly and then try again. It should work fine.
Let me know if it wasn’t the issue at all! As I said, for some reason, I can’t see the image that you posted.
Mostapha
