i am trying to run an annual daylight with honeybee and i keep getting the error list below.
i tried using different weather files and still it turns red. What could be the issue?
Does it run if you use a different weather file?
no it does not run i tried different weather files
Hi there
I have the same issue
Could you solve this problem?
Try to update with LB Versioner and then sync the components on the canvas with LB Sync Grashopper File. Restart Rhino and run the simulation again. If there is still an error, please upload the logs file. You can find this txt file in the __logs__ folder of the project folder.
