hi,
how can I fix the problem of running following file and error of run component?
the simulation is for annual daylight with BSDF material on south glazing.
annual-daylight-bsdf.gh (499.0 KB)
thank you for help
hi,
thank you for help
I believe it is because you use the output of Mass2Zone (Closed Brep of the box) as input for _HBObjects in runRadiance. Try the setup as shown in the image. This will create HBSurfaces for the 6 faces of the box. You can further manipulate the materials for each surface - as shown in the image it will just use the default material for each surface (4 walls, 1 floor, 1 ceiling).
