Annual daylighting cannot ran successfully
The given annual daylighting example cannot run successfully. Please tell me why is the case. It cannot run either with 1.6.0 or 1.8.0 version. I am attaching the log file with this topic.
logs.log (20.7 KB)
Hi @IRossTaketheeRachel, how did you install Ladybug Tools?
Here is the error that makes me think you have an old version of radiance installed on your machine that is missing some of the new options.
2024-06-04 11:31:31 INFO: Started running GenerateSunpath...
2024-06-04 11:31:32 INFO: Usage: gendaymtx [-v][-h][-d|-s][-r deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]
The lack of -n option is the source of the problem here.
Try updating your Radiance installation or use the Pollination Grasshopper single click installer to get the correct version of Radiance that is compatible with Ladybug Tools.
Many thanks for your help!
