Appcrash, fault modul opennurbsx64.dll
I have a new problem that I have been trying to find a solution for it for about a week, but I didn’t succeed.
During running galspagos with honeybee, the rhino stops working, it may happens after 10 minutes or 2 hours.
I have attached a picture of the error.
I would really appreciate it if someone could help me.
Thanks in advance.
Hi Fahimeh,
This can be because of Rhino, Galapagos or Honeybee. You should report this under Errors and Bugs with an example file so hopefully David can re-generate the error and tell you why this is happening. I’m not sure if David will see the error here.
Mostapha
Thanks Mostafa,
Ok, I will write there with an example.
Fahimeh
Hi Mostafa,
I wrote my problem in this link:
http://www.grasshopper3d.com/forum/topics/appcrash-error?commentId=…
Unfortunately, David couldn’t help me find the problem, at least he suggests waiting to see if it will crashes on Rhinoceros 6 and that’s a long time for me.
Do you have any other suggestion for me with this file? Is there any other way to get the results (I want to find the best angle and dimension of a lightshelf in every hour on some specific days). It took a long time for me to learn Hb and it’s not logical to leave in this stage inconclusive.
Thanks
5-1.gh (512 KB)
Hi Fahimeh.
I checked your file and I’m confused what you’re trying to do. Are your goal is only to model a room and optimize it for daylight or is it going to be also an energy model at some point? Is the size of the room stays the same during the whole study?
In any case you need to model light-shelves as separate surfaces and not part of the zone.
Also there is also so many extra components in your definition. I would only leave the components which are critical to the study for an optimization case as you need to run so many cases.
Let me know what are you exactly trying to do and we’ll look for alternate solutions.
Mostapha
Hi Mostafa,
Thanks for looking at my file,
I didn’t understand why lightshelf shouldn’t be a part of the zone.
Using the components such as TT toolbox, was because I wanted to save results in any stage that Rhino stops working, so exported data to excel, it can be deleted, not important.
My final goal is to build and find the mechanism of dynamic lightshelf,
an exterior lightshelf that its angle is variable, and an interior lightshelf that its length is variable, the room and the window stays the same during the hole study.
for this, there are 2 ways (If I am making a mistake, let me know):
  1. to optimize lightshelves based on desired illuminance in each hour.
  2. to optimize lightshelves based on thermal and lighting energy in each hour.
Simulation will be repeated in some days as sample for expanding to the whole year.
I am doing the first step (although I wrote an algorithm for the second one, but I thought it takes longer time and the appcrash possibility is higher than the first one)
Hope that explanation was good and enough,
thanks a lot
Fahimeh
Mostafa,
did you read my comment? Do you have any idea?
