I would like to assign a new construction set to my rooms. However when I do so, my model does not display the correct roof areas anymore (One basement room seems to have a roof area now). I am not sure what can go wrong since I do not modify my geometry…
Just to give you a bit more details on the way I build my energy model. I used the workflow that was given as a sample with the installation files (“full energy model”):
step 1) the different rooms are closed Breps, they are merged together and then “processed” via the two components “IntersectMassII” and “HB intersect solids”.
step 2) I individually retrieve the resulting breps and create rooms with the component “HB room from solid” (+ assign a construction set and a program).
step 3) I combine all the rooms and I use "solve adjencies"
step 4) I retrieve the different rooms and assign windows
step 5) I create the energy model
Is there a smarter way to proceed, to avoid such problem as mentioned above? Should step 1 take place at a later stage?
Thank you so much for your help!
