Arrange test points, as desired
Hello friends,
I study topics of the test points, but did not find an answer.
Does anyone have a solution for arranging test points arbitrarily? (For example, spiral-like)
it can greatly help to provide results that are appropriate for the type of research.
You can always manually select the points using a native GH Point parameter component before you plug the points into the recipe component. This will ensure that the points are in the order you want. It’s a little more difficult to restructure the mesh to have faces that are in a certain order but that’s also possible with a little Rhinocommon SDK scripting.
