Bake problem in shadow range analysis
I came across bake problem after shadow range analysis. see as below:
Fig 1: The normal result I got
Fig 2: Failure of baking
Can anyone help?
Thanks in advance!
I’ve attached the gh. file which is almost the same as the example one.
Library_Shadow_Range_analysis.gh (387 KB)
Hi Maria, Haven’t tested your file but what about right click and bake?
Hi Mostapha,
I’ve both tried to right click and bake and use Boolean toggle.
Maria,
I suggest you update you file to the latest development. There you can find the new (wonderful) bake options Chris implemented.
See attached a working file. I just added some geometry since you forgot to internalise yours.
Library_Shadow_Range_analysis_AY.gh (413 KB)
Hi Mostapha,
The problem is the display mode I chose. Everything went well when I changed to another display mode. What a silly mistake I made…
Awesome. Glad to hear that the _bakeIt is working well!
