Dear LB community,
Have you faced this before that Ladybug Monthly Bar Chart does not bake the legend by setting the bakeIt_ input to true?
Farhang
Dear LB community,
Farhang
Are you using Rhino 6?
Thanks @devang. But with this updated barchart, setting the baking to true crashes the component.
I attach my file, in case you have time to have a look at it. If you just run EnergyPlus on the centre of the canvas, you can see that the bar chart at the bottom right hand side of the canvas crashes.
Farhang
EM_BarChartTest.gh (862.3 KB)
Thanks for the file. I will look into it
Hi, I wanted to confirm that this produces the same error for me.
But if I bake by right clicking then it works:
Guys,
I tried the file provided by @farhang.tahmasebi. It works without error at my end. I tried on two machines. Following is the rhino version.
Version 6 SR22
6.22.20028.13281.01/28/2020
Can you please share what’s the error message?
@Devang, the error was this one:
But as I tried to replicate the situation, I realised if I save the file with the updated Barchart, restart Rhino and open the file again, it will work. I hope this helps you if any refinement is necessary.
I wonder, how we can access this updated barchart in .ghuser format? Perhaps if it is included in user objects folder and loaded from the beginning, it will work without this issue.
Thanks
Farhang
If I save after updating HB Components it does not produce error any more, but it does not bake it still
EM_BarChartTest-updatedHB.gh (866.5 KB)
Turning on the layer solved it did not think about this!
