Hi @chris,
On setting the LB_versioner to True I go the following error.
1. Solution exception:Failed to find C:\Program Files\ladybug_tools\temp.
I am using version 1.4.0.
Hi @chris,
If you have installed Ladybug Tools in Program Files, you have to run Rhino as admin in order for the Versioner to succeed. So right-click Rhino and select “Run as Admin” and then it should work.
You just didn’t uninstall your old Ladybug Tools, @devang . If you use the HB Config component, it should make it clear that you that the Ladybug Tools you are actually using is in Program Files:
I should also clarify that the only reason why you have Ladybug Tools installed in Program Files is because you ran the latest single-click installer from Pollination. So other people on this forum will only have this issue right now if they used that.
And, perhaps most importantly, you should see that running Rhino as admin allows you to run the Versioner.
