Bulding masses error "out of range"!
hi guys,this is my brep and i want to do some daylight anaylisis on my building but when i connect it this happen
B1.gh (474 KB)
These forms are very complicated for auto-zoning with component but at the same time you can create your own grasshopper definition to split the zones fairly easily.
In any case are really suggest to change curved surfaces to planar surfaces. If you run the analysis for these geometries it will take very long and it won’t make a real difference in the results.
Hi Mostapha,
What would be the best way in this situation: bounding box or mesh brep (or rebuilding)?
Btw, I’ve seen your reply, thanks.
