hi, all
i try to run the “outdoors_airflow” case with butterfly and came across a problem shown below.
it seems that the software failed to write the getid.bat to get id from docker.
however, i think i have installed the openFOAM correctly on Windows. i have successfully get a id from docker and run a OpenFOAM case manually. please see the attached screen shot
is anyone can help me to solve the problem.
thanks a lot.
