How can I solve the following problems ??
not sure but your user name has a space in between… that usually causes issues for retrieving files with any ladybugtools component…
Thank you for your answer. I have changed my username, but the same problem still arises. I found nothing in this folder. What should I do?thank you
Hello, @OlivierDambron ,my problem has been solved. I changed the user name and downloaded the outdoor wind environment analysis battery again. It can run normally. Thank you again for your reply!
