Hello everyone,
I am trying to install Butterfly on the Rhino 7. I was following all the procedure from your website and installed OpenFoam and VirtualBox. I start them before running Rhino as the Admin. However, when I try to run some of your examples, I get this error:
- Solution exception:Error checking TLS connection: Error checking and/or regenerating the certs: There was an error validating certificates for host “192.168.99.102:2376”: x509: certificate signed by unknown authority
You can attempt to regenerate them using ‘docker-machine regenerate-certs [name]’.
Be advised that this will trigger a Docker daemon restart which might stop running containers.
Could you please explain to me how to fix it? Thank you!
