Hi, would really appreciate if someone can help. May I ask why when I Load mesh in Butterfly it loads the mesh from another file instead of the current file I’m working on ? This is really weird and am not sure what to do. Would really appreciate if someone can help, thanks.
Butterfly Issue.gh (13.4 KB)
Geometry is missing in my environment. And your gh file is not running blockMesh, so I can’t see the mesh. It probably still has the result of a previous run.
Hi, thanks for getting back, do appreciate it. I think the Load Meshes update after running the Block Mesh Component. So the meshes only update once Block Mesh has been turned on. Thanks for getting back.
