A student of mine is struggling installing any of the CFD programs for using with Butterfly (BlueCFD/OpenFoam).
What will be the recommended one?
Will appreciate good installation instructions for Windows10 OS.
@minggangyin , maybe you can give some hints here?
Hi @AbrahamYezioro Butterfly used blueCFD to excute CFD simulation. BlueCFD used openfoam as engine. So you only install BlueCFD and connect to Butterfly.
Thanks @minggangyin !
Can you confirm the recommended version and tell if the instructions to install are those in the github? Or the procedure is easier now?
Butterfly only support blueCFD 2017-1 version. You should install this version.
