Butterfly Snappy hex mesh Running time
I’m new to Butterfly, I have installed openfoam on my computer. My computer (i7-9850H with 32G ram and SDD drive)
I was following the tutorial, and the snappy hex mesh component took like half a hour to run. nothing fancy just 2 blocks from the example.
I have also set the RHINO unit to meters and tolerance to 0.1.
Is this normal? or I have done something wrong?
Thanks …
Did you run snappy with one or multiple CPUs?
You can check this by checking your folder or logfiles if deconstructParMesh/deconstructPar has run before your snappyHexMesh (this will create the folders foam/processor001, foam/processor002 etc…
It can take half an hour on one cpu. Also depends on the cell size around your blocks.
