Butterfly TLS connection error
#1
I have been facing with TLS connection error.
Do you have any suggestions for solving it?
Thanks,
Gunsu
#2
I wish I had a simple solution for this. Based on the error it can’t find the default VM. Try to open the VM and start default manually.
#3
Dear Mostapha,
The thing is VM worked out fine. However, there is lot more.
First, i have completed the setups of rhinoceros- grasshopper -butterfly- openFOAM, and currently running them as administrator. The problem is I have been facing with SSH, TLS connection and certs problems (error codes as 125 and 255 most of the time).
Then to solve SSH problem, I have downloaded cygwing and SSH files were downloaded and seemed working fine. However, VM still has problems with SSH.
I tried many many things and obviously need your help. Thanks in advance!
All the best,
Günsu
![VM1|690x477]
#4
I also encountered with same problem. As I search for the problem there are many suggestions but not worked any of it. Will it be helpful if we change Virtual Machine software?
#5
Dear Friends,
The problem is solved and I would like to share it with you hoping it to be a solution in case of any need. Docker machine has a config.json file located in C:\Users\Username.docker\machine\machines\default
The problem in running is due to the docker, which cannot find the host address or trying the wrong address writen in config.json.
The solution is:
  1. Write ‘docker-machine env default’ command via cmd to see what the IP of the host is searching for.
  2. The command will get you to have the following strings:
SET DOCKER_TLS_VERIFY=1
SET DOCKER_HOST=tcp://192.168.99.105:2376
SET DOCKER_CERT_PATH=C:\Users\Username.docker\machine\machines\default
SET DOCKER_MACHINE_NAME=default
  1. Then select 192.168.99.105:2376 part of the SET DOCKER_HOST=tcp://192.168.99.105:2376, copy it and paste it in HOST bracket in config.json file.
That’s it.
Hope it works for everyone.
Best,
Gunsu
